Western Digital Elements HD Make a sound like Tik Tik Tik
My Western Digital Elements HD Make a Sound as Tik Tik TiK after connected to laptop and Not recognized
please your help
Is dit een goede vraag?
please your help
Abdul-Rahman Salem this is most commonly indicative of a Hard drive error. The ticking from the drive means that is has an internal problem which is commonly known as "lost servo". The ticking sound is the search arm going back and forth. Check the BIOS on your laptop to see if the drive still shows up on there. You can always try a new cable, check the drives connection in the external case. Sometimes, replacing the HDD controller board can repair this. Ultimately, it sounds like your drive has failed.
Was dit antwoord nuttig?
Although it is considered new, I don't know why this is happening
My goal is to transfer the data on it
is there a solution ?
@Abdul-Rahman Salem you can't, since it is not working. There is no software for this and do not consider opening the drive either. If the files are important to you, try a data recovery specialist (expensive) to recover those. There is no other way.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 356
