Ga door naar hoofdinhoud
A 6'' 1080p budget phablet available through T-Mobile and manufactured by Coolpad. Model number C3701A. It was released in August 2017.
5 Vragen Bekijk alle
My phone keeps saying that it's charging when it's not
Sorry for incorrect phone model, but I couldn't find my phone model in the list of models, so I just went with the one that most closely resembles my phone. I have a T-mobile Revvl 4, and the phone says that it's charging when it's not and the screen just randomly turns black, and it's had issues like this for 9 months. I have to constantly turn it off and then back on again to get it to temporarily work again. However, then the screen just turns black again, and the issue continues. My phone briefly stopped having the issue for about 2.5 months. On December 14, it was raining and only a little bit of rain got on my phone, but not enough to cause any water damage. I'm not sure if it's because of the rain or not, but now it's going back to saying that it's charging even when it's not, and the screen is randomly going black again.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
so my only guess is that the fuses on the board that take in the charge and send it to the main chip are faulty and the screen randomly turning off I don't know much about that try updating the phone see what happens
Was dit antwoord nuttig?
@kaylani could be a battery issue. I would definitely start with that. Also, check the charging port. Make sure the are no bend pins, corrosion or debris that are creating any obstruction. Check your circuit boards for corrosion and other visual cues that something does not look right. You can always post images with your question. That way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Voeg je antwoord toe
Kaylani Thomas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 162
