Ga door naar hoofdinhoud
De Xiaomi Redmi Note 9 is een mid-range smartphone van Xiaomi die in april 2020 werd uitgebracht. Het toestel heeft een 6,53" IPS LCD-scherm, een 48 MP hoofdcamera, een vingerafdruksensor aan de achterkant, een 5020 mAh-batterij en draait op een MediaTek Helio G85.
Phone drop in water
Yesterday my phone drop in water it was working fine but the flashlight was on and not turning off so i power off the phone but flashlight is still on and not turning off and now my phone is not turning on but flashlight is on
Is dit een goede vraag?
1 Opmerking
Phone drop water not on my phone
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
saleemkhanx001, The first thing to do now, is to stop trying to turn it on and DO NOT connect a charger.
You’ll have to open uptempo phone and remove the parts on the inside, for best results. Inspect the boards closely for corrosion and damage, you’ll need good lighting and possibly a magnifying glass. Use some distilled water and gently use a brush (fex a toothbrush) and clean the boards and case. Apply gentle pressure, but do not overdo it.
Once you gone over it with distilled water, do the same thing with >99% isopropyl alcohol. The IPA displaces the water, and IPA evaporates in seconds to a couple of minutes. Once you’ve cleaned everything with IPA and have let it dry off, make sure once more that there is no damage or corrosion present on the boards.
Connect the screen and battery again and check if it will boot. I prefer to test the devices for 100% functionality before I close it back up. If you’re lucky and there hasn’t been any bad damage, your phone should start again, but remember: even one single drop of water in the wrong place can be truly destructive for a phone!
Was dit antwoord nuttig?
Score 2
My phone had repaired but still facing problems related touch not working properly and front camera, rear flas light not working
Voeg je antwoord toe
saleemkhanx001 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 558
