Ga door naar hoofdinhoud
HP Envy 15t laptops include the letters “HP” in a lower-case font in the center of the display’s lower bezel.
3 Vragen Bekijk alle
Blue screen of death
Hello I was using my laptop with no problem since I got it so I tried updating windows and it was stuck on %100 so I restarted my laptop thinking everything would normal ones it's on but I got the blue screen instead with critical process died stop code , I have tried everything but nothing works resetting,startup repair, uninstall updates nothing works but when I try system restore I have to tick a little box on the disk I'm using but I don't have a mouse pointer to tick the box, please help me.
Is dit een goede vraag?
2 opmerkingen
@vybzonline update which part of Windows? Update to what?
door
@oldturkey03 I was updating the windows 10 because it was not up to date.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
How to fix a Blue Screen of Death on a Windows PC
Uninstall incompatible software.
Run a memory checker.
Check for hard drive errors.
Remove non-essential peripherals.
Replace defective or incompatible expansion cards.
Run Setup Diag after a failed Windows update.
Perform a clean install.
Regards,
Will
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for your reply
door
Hello I will suggest you the following.
  1. Use specialized BSOD repair software.
  2. Uninstall critical third-party programs.
  3. Run SFC.
  4. Check all drivers if any driver is outdated update driver.
  5. Backup your data and clean install Windows
Voeg je antwoord toe
Abdul Malik Suraj zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 165
