Ga door naar hoofdinhoud
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Vragen Bekijk alle
DS Lite isn't charging Constantly, charging light goes off.
The charging light was red so I put it to charge but the orange light goes off for a few minutes so it was impossible that in a few seconds it completed charging. But every time I unplug the charger and plug it in again the light goes on, but the same thing happens again.
It isn't an adapter/cable issue.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@xyla let us know how you determined that "It isn't an adapter/cable issue." If that is correct, you want to replace the battery. If a new battery does not yield any better results, disassemble your DS and check the board for corrosion and failed components in the charging circuitry. Post some pictures of both sides of your board with your question so that we see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Nintendo DS Lite Motherboard Replacement
Nintendo DS Lite Motherboard Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
25 minutes - 2 hours
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
Voeg je antwoord toe
Xyla zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 71
