Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor Panasonic Viera-televisies.
Tc-p50st50 flashes 6 error code
I have a 2012 Plasma that will go into a lockout with 6 error code flashes, I can reset it using the power button on the tv, it will sometimes work for a week following the reset before doing the same thing, the next time the reset may only before a matter of seconds. I have checked the boards for signs of failures with not obvious problems. The troubleshooting for 6 flashes states that the most probably fault is the sc board, with the next most probable being the “a” board. I am uncertain how to determine with certainty which board is causing the problem. I did check the boards for loose screw grounding connections, there are signs of arcing in a few locations. Any help on how to proceed is appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @kwm
Here's an image that shows how to troubleshoot a 6 blink error code to know whether it is the SC board or the A board that is the problem in your model TV.
(click on image)
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks I will give that a try,
door
Voeg je antwoord toe
KevinM zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 406
