Why is my device so slow
What can I repair that it should be faster
Is dit een goede vraag?
Here's what you can try and what Google recommands, in short:
In this article by Kevin Purdy you'll also find other tips to speed up your phone or tablet, more specifically:
Was dit antwoord nuttig?
I don't understand abt 3/4th of what is said here. And, these items are not found when I do a search, like Developer something. That is not located on my Tab A 8. Other items mentioned here are not found either. So, what do I do now? Toss it? It's almost worthless, it's so slow.
@suzannec43668 what tablet do you have? A SM-T290 or a SM-X200 etc?
The very first thing you want to do is to get rid of all unnecessary preinstalled apps. To disable those go to Settings ==> Apps ==> App Manager ==> Select the app ==> Disable
You also should clear the cache and files that are just hogging memory. Get rid of them by Settings==>Apps==>App Manager==> Clear Cache/Clear Data
Next I would turn off background processes, by Settings ==> Developer Options ==> Don’t Keep Activities
If everything else has no effect, you may need to consider a factory reset. Make sure that you have backed up your data (Images/files/contacts etc.) since those will be lost
Suzanne - 'Developer Options' is hidden by default.
To unhide the Developer options menu:
1 Go to "Settings"
2 Tap "About device" or "About phone"
3 Tap “Software information”
4 Tap “Build number” seven times.
This will unhide the 'Developer Options' settings where most of the things discussed here can be done.
My tab is taking more hour for charing
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 273
Altijd: 10,321
