Ga door naar hoofdinhoud
Display dead after battery replacement
I followed these instructions with a new iFixit battery for my early-2013 MBP. It was working fine (other than the battery not holding charge) when I started (it's all backed up, that's not the issue, I just want to be able to use this old friend).
After reassembly, I connected magsafe to AC, and the machine immediately chimed. However, the screen remains completely black.
Here's what I know: on connection, the magsafe charging led is green, then turns orange; the CapsLock led is active; I can power down (no CapsLock led) and back on (chimes, CapsLock led working) with the power button; I've reset SMC and PRAM with the button + powercycle combinations; there's no signal on the hdmi port (the monitor I connected to does not see a signal); I've disassembled and reinserted the display data cable twice (Step 29 in attached instructions).
Does anyone have a suggestion about something I could try next? Thanks in advance -- wylbur.
Is dit een goede vraag?
4 opmerkingen
Using a flashlight pressed against the screen at a sharp angle are you able to see a faint image of your desktop and its icons?
door
Thanks for this idea.
I just checked 2 different flashlights, and no, the screen has nothing on it (it would be a login screen I think but I can't see a colored background or anything else).
door
What happens if you disconnect the battery and try to power it on with just the MagSafe charger plugged in?
door
@Duck great question! I will need to get back to my shop to test this, I hope to have an answer in 24h.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
At this point I would re-connect your old battery to see if that altered things.
Was dit antwoord nuttig?
1 Opmerking:
Ah, regrettably removing the battery was destructive. As I detached the battery cells from the adhesive (even with a liberal use of the solvent) connecting them to the chassis, I wrecked their cables. Alas, this might not have been a successful repair. Thanks for your thoughts.
door
Voeg je antwoord toe
Patrick Ball zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 338
