Ga door naar hoofdinhoud
A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
88 Vragen Bekijk alle
How to remove completely stripped screw?
So I stripped the screw to the point where it’s just a round hole. I tried superglue and it didn’t work, so the hole is caked with the stuff as well. How can I remove this screw? I presume I would need a drill, but what kind of drill might work for the controller?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi
If it’s in a hole carefully drilling the screw head then removing what’s left with pliers is probably you best option
It it wasn’t in a hole you might be able to cut a slot into it for a flat head screw driver to go in into but this is probably not the best option for you
You could also try using a rubber band on the end of you screw driver
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
C K, this is only to complete the excellent answer by @hellomacos; You could try these precision screw extractors.
I’ve had good success using those, in many cases.
Precision Screw Extractor Set Afbeelding
Product
$24.99
Score 3
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 143
Altijd: 2,523
