Ga door naar hoofdinhoud
Deze nieuwe iPhone 14 Pro, de "kleinere" ''flagship''-telefoon van Apple die gelanceerd is op 16 september 2022, bevat een 6.1" ProMotion OLED-scherm, een driedubbel lenssysteem voor de achterste camera, 5G, en een nieuw "Dynamic Island"-ontwerp rondom de voorste camera en bovenste sensoren. Opvolger van de iPhone 13 Pro.
22 Vragen Bekijk alle
In back side one white spot
I’m recently buy this phone dark purple I phone 14pro but there is one white spot on back side. I’m asking to shoe they said to contact in IFIX. I’m buy 3 phone at time but 2 phone is colour but mine defective. Apple giving this type service to the customer I’m not happy with this.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi Mahendra,
If I'm reading your question correctly, you just bought a new iPhone 14 Pro and there's a defect in the color on the back glass, is that right?
At this point you have three options.
  1. Return the phone for a replacement. Given that this is the latest model and should still be under warranty, you should be able to get it replaced.
  2. Replace the back glass. This is an extremely difficult repair, as the adhesive used on the rear glass of most iPhones is extremely strong, so it requires a heat gun or laser to loosen the glue enough to be able to chip the glass out of the frame.
  3. Replace the entire rear chassis. This saves you the difficulty of removing the rear glass, but that gets made up for by the fact that you have to transfer every single component inside the phone to the new housing.
Unfortunately, your phone is so new that no guides are available for replacing the rear glass or the chassis; you may be able to find YouTube videos, but none of the regular repair sites I'm aware of has any information on the 14 Pro.
I'd strongly suggest contacting either the seller or Apple itself to see about a warranty replacement.
Was dit antwoord nuttig?
Score 1
i have same issue.
any update my freind?
2 opmerkingen:
what issue do you have, screen or back glass ?
door
purple back of my 14 promax has one small white spot.
door
Voeg je antwoord toe
Mahendra Kumavat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,272
