Ga door naar hoofdinhoud
De Time Capsule Model A1302 is de tweede generatie draadloze router en netwerkopslagapparaat van Apple, uitgebracht in maart 2009. De meeste informatie uit deze reparatiehandleidingen en demontagegidsen is ook van toepassing op het oorspronkelijke Model A1254.
Time Machine internal drive replacement using SSD instead of HDD?
Hello Everybody.
My A1302 Model internal Hard Drive is soon going to RIP (keep getting constant errors that the Disk Image can't be created / Is damaged ) so a drive replacement is imminent.
My question is, would it be wise to replace the internal drive with an SSD ? Or should I stick with a standard HDD ?
The old drive is a 1TB and i'm going to use a 1TB drive as a replacement.
Thanks is advance for your help.
Cheers
E_
Is dit een goede vraag?
Score 1
2 opmerkingen
How it ended? Have you noticed increasing speed? Or some different experience?
door
Cuál es el máximo de almacenamiento SSD que podría admitir esta unidad A1302? Gracias
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
It depends! It you are using the drive for backups then stick with a HDD as it’s cheaper when getting into the larger sizes. If you are using the drive to augment your data storage with direct access then you might go with a SSD. Even still the Time Capsules I/O speed is not very fast so you may want to get a better external drive.
Was dit antwoord nuttig?
Score 4
6 opmerkingen:
Hy Dan & thanks for your answer.
Seen that there's no price difference nowadays in France between an 1TB HDD and SSD I think I'll go for the SSD.
Less power consumption, less noise and as stated in a few articles here
How do I Upgrade the new AirPort A1470 to SSD?
, write speeds over ethernet are a lot faster.
This here looks like a good replacement Crucial CT1000BX500SSD1 but any suggestions are welcome.
Cheers
E_
A quick thought … if i put an SSD inside, is there a specific place a have to stick the temperature sensor back on ?
door
I was thinking 4 to 8 TB for the drive as often people need deeper storage. But a one TB drive also works!
It’s not the Ethernet speed that holds you back the SATA controller logic Apple used won’t deliver what the current generation of SSD’s can offer.
Place the sensor near the drives connector as that’s where the micro-controller is,
door
@danj Thanks for your insight on the subject.
Cheers
E_
door
What is the maximum SSD storage that this drive supports?
Tanks
door
@dani47292 - I wouldn't go to large as the WiFi and SATA logic is not that powerful in this series. A 4TB is what I would go with. Others have used 8TB drives.
door
1 commentaar meer tonen
Voeg je antwoord toe
eric zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 5,334
