Ga door naar hoofdinhoud
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Vragen Bekijk alle
Can not identify part (battery replacement tutorial)
So I was following the tutorial for battery replacement for Surface pro 4. and when I was removing the motherboard. this part popped out (I think under it?). And I am obviously stuck with reassembly. Can someone advise what is it and where to put it? Please?!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That is a support bracket for the heatsink. I'm assuming that the batteries that you replaced were swollen.
I was actually searching the forum today to see if anyone has a method of reattaching them. (I have a couple that also had swollen batteries.)
In addition to supporting the heatsink, it also transfers heat to the metal case.
You can use the Surface without it, it just means the thermal transfer will be diminished.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Aleksandre Akhmeteli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 29
