Ga door naar hoofdinhoud
The Sansa Clip+ is a music player by SanDisk that was released in 2009.
12 Vragen Bekijk alle
usb charging port just broke off on charing cord, can I reattach?!
Hi! I was literally just using my mp3 player and as the battery went low, I went to charge it, and the charging port pulled out the charging jack piece and i don't know - can i reattach it? Is all lost? Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @ecrayons
You may be able to solder it back onto the board.
Here's the ifixit Repairing Loose Headphone Jack guide that will help.
It shows how to open the player so that you can access the board and resolder the USB port back on. The port is seen in the image in Step.2.
You will need to have smd (surface mount device) soldering experience and tools to do the repair.
If you don't want to do it yourself, any reputable, professional mobile phone or electronics repair service should be able to fix it
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
elizabeth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 20
