Unable to Activate "An update is required to activate your iPhone"
I just got this iPhone 7 to repair. It was boot looping, so I put in a different battery. It was still boot looping, so I put it in recovery mode and plugged it into my computer and updated it. I eventually got to the iPhone Unavailable screen, so I put it back in recovery mode and restored it. It went to the usual "hello" screen and I got to the part where the it tries to activate, and all it says is "Unable to Activate an update is required to activate your iPhone. Learn more at apple.com/support"
I already updated it, so this error isn't making sense to me... Could this be an issue with the carrier or a hardware issue? I had another iPhone 7 previously that had a damaged chip that made it so that you couldn't connect to cellular or activate the device. Could that be the issue here? Or is it simply iCloud locked?
Thank you for the help!
Is dit een goede vraag?
7 opmerkingen
did you put in a SIM card when setting up? is the device carrier locked?
door Kuba
I didn't put a SIM card in. Is there a way to find out if it is locked?
door Crosby Grim
https://imei24.com/check/iphone_icloud/ you need to input the serial number or IMEI number and it'll tell you if it's locked or not
door Kuba
use 3utool and you can skip activation, if it fails on that aswell its possibly a baseband issue
door daniel
I meant is there a way to find out if it is carrier locked...
door Crosby Grim
2 commentaren meer tonen
