How do I fix a broken motor driver side wing mirror?
Drive side mirror doesn't fold open or close, nor does the buttons to move the mirror on the wing mirror. The other side works perfectly.
Is dit een goede vraag?
Check the fuse. If it's not getting power that's the first thing I would check. Location will be in the manual.
Was dit antwoord nuttig?
Cek dinamo, dan bersihkan. Atau Jumper termal fuse dalam dinamo.
i had the same problem 1020792 12V DC 280 rearview folding mirror motor for Peugeot 208 3008 2013-2016 this is the code for the electrical motor
you can find a youtube tutorial how to take the mirror apart and replace the electrical motor.
make signs before diasamble the main frame. i did not make signs and ai had to mont and disable agains 2-3 times before figureing what is the right position
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 240
Have you checked to make sure it's getting power? Have you checked the ground for it as well?
door brandon k
