Ga door naar hoofdinhoud
The Suzuki Swift is a subcompact automobile manufactured by Suzuki, a Japanese automaker. The second-generation Suzuki Swift was introduced in September 2010 and replaced with a new generation in February 2017.
I loose power when accelerating and sometimes when in traffic
Intermittent stalling immediately after starting or punching gas. Sometimes also in traffic. I have tried changing the CVT, testing sensors, What might be the issue?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like a fuel injector issue. Could also be a vacuum leak.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I have to check this...But how would I check a vacuum leak ?
door
That is difficult unless it is a big leak and you can hear it. Disconnecting or pinching off vacuum lines might give a clue, but that involves much understanding of what you are affecting. My bet is on the injectors.
door
Hi mate. Did you fix your problem?
What if your throttle was clogged?
2 opmerkingen:
I've fixed a clogged catalytic converter that did something like this. I drilled a 3/8" hole in it.
door
might be fuel filter also that need to be cleaned or replaced..
door
Voeg je antwoord toe
William Afrika zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 650
