Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Vragen Bekijk alle
There is no Ground cable.
Hey! I wish your happy new year!
I get a new logic board for my iPod, but there is no ground cable
to connect main frame. A ground strap (Silver color, and it could
show remove click wheel. ) is not sale whole of the world, is it
meaning to make a ground strap for myself?
Is dit een goede vraag?
Score 1
2 opmerkingen
Thank you Mr. Oldturkey03.
I try to assemble "without ground strap" and I will report about this issue.
door
Sounds good and best of luck to you :-)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Tsutomu Niimi, I have replaced a lot of logic boards on that model iPod and never have had any issues with NOT having the ground strap. However, if you are unsure, you can use the logic board outline as a pattern and make a ground strap out of aluminum foil. Good Luck, I hope this helps.
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
Dear Mr. Oldturkey03 and iFixit menbers, and all.
I made a ground strap out of aluminum foil.
My iPod works completely.
Thank you for your nice advice!
door
You are welcome....;-)
door
Voeg je antwoord toe
Tsutomu Niimi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 887
