Ga door naar hoofdinhoud
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.Also known as the Samsung SM-G998U1
20 Vragen Bekijk alle
no service after screen replacement. can this be fixed?
i had my sreen replaced and now i experience seriously degraded or no signal. i read the answer about that the original antenna needs to be kept. but if it is too late for that is there a fix? i actually paid over 400$ for this problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @jaredscott,
Take it back to the repairer and show them the problem.
Most reputable repairers give a guarantee on their work even if it is only for 1 month.
The exception to this may be if the phone had been water damaged.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
I'm stuck at original antenna has to be kept. Of course it does, that's what provides the signal. So the shop didn't refit the antenna?
door
Hi @strongbow
At $400+ you'd think that the repairer would know this. If it's lost then they should replace it.
The phone should be tested and in a fully working condition when it leaves the repairers.
door
@jayeff some shops are more money orientated than about the quality of their work. I for one make sure every part that comes out of a phone goes back in again. Then every function is checked before it goes back to the customer. I can't believe these shops exist.
door
@strongbow
They can't be relying on repeat business or referrals then ;-)
door
We have shops the same. Can't believe half the repairs we get that other shops have 'fixed'.
door
Voeg je antwoord toe
Jared S Fidler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 462
