Ga door naar hoofdinhoud
20-inch, 23-inch en 30-inch aluminium lcd-beeldschermen geïntroduceerd door Apple in juni 2004. Modellen respectievelijk A1081, A1082 en A1083.
Cannot make it run on windows 10
Good night friends. I'm trynig to make it run on windows 10 x64, using a Late 11 MacBook PRO, that doesn'n have a video card like NVidia, only the Intel 3000. With the adapter I made it run in the MacOs, but nothing on windows. What I can or should do?
Is dit een goede vraag?
2 opmerkingen
Have you downloaded the correct drivers for Intel 3000 graphics?
door
Different macOS versions support different BootCamp releases which in turn which Windows releases is supported.
What macOS and BootCamp release are you using?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Afternoon,
Is this machine a dual boot? if so, can your friend forego windows or is it necessary?
Note the release year. It is a 2004 monitor you are trying to hook up with a 2011 computer running a 2015 (Likely newer) operating system. Let that sink in.
What port does the display plug into on the MacBook (Firewire? Tbt? HDMI?) And where did you source this adapter from?
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Well, I can go without Windows if needed, just have to use it for a system that runs only in it, but everything else runs on MacOs.
I know that the monitor is old, as so the Macbook and the systems are newer, but with the MacOs, as said, it runs great.
The adapter was bought on Amazon (if that's what you asked) because the monitor doesn't have a Minidisplayport or TB cable, so, I'm using from the DVI to a Thunderbolt.
door
@Mauro Lúcio Martins Marques Apple's Boot Camp 4 supports the 32-bit of Windows 7 on this model (late 2011) Boot Camp 5 supports the 64-bit versions of Windows 7 and Windows 8.
Windows 10 are supported from 2012 and later, but this may help: https://wpguru.co.uk/2019/07/installing-...
door
No matter what I try or do, the screen remains black. Even the power button works, if I use the Bootcamp's control panel, but nothing else. Think I'll have to let it go...
door
@Mauro Lúcio Martins Marques if everything working under macOS but no under Windows it’s 100% software issue.
Here is other discussion:
https://answers.microsoft.com/en-us/wind...
door
I simply cannot figure out what to do. tried everything told, even followed the article above, but I will let windows for an unique activity and will use MacOs for the rest, there is no other way.
door
Voeg je antwoord toe
Mauro Lúcio Martins Marques zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 1,150
