Ga door naar hoofdinhoud
iMac Black Screen No Chime Led 1 Fans Rev
Hi There.
I have a problem a back screen issue.
The fans turns on with the hdd and DVD drive.
I checked the onboard diagnostics and LED 2, 3 and 4 are off.
I have replaced the PSU but but still a black screen.
I have replaced the cmos battery but still black screen.
I have baked the gpu but still black screen.
Ask for any info about Imac.
Edit.
I forgot to mention I plugged in a different keyboard when it was working and when 15 min past it crashed and I could turn it on but it would crash less then 10 min in it would crash. The next day it would not turn on I have the issue now.
Update (01/08/2023)
@danj
This is the gpu
Update (01/08/2023)
The specs
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sounds to me Like A Scary failed logic Board Or CPU!
Take it The board out and look for any corrosion,
And Check The CPU
Guide: iMac Intel 21.5" EMC 2428 Logic Board Replacement iMac Intel 21.5" EMC 2428 CPU Replacement
iMac Intel 21.5" EMC 2428 CPU Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
3 - 5 hours
iMac Intel 21.5" EMC 2428 Logic Board Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 4 hours
Was dit antwoord nuttig?
Score 4
61 opmerkingen:
door
Hmm... I'd say try reseating the CPU.
door
@beanman56
It didn't work I reseated the CPU. Still doesn't work.
door
@tomytom - Okay sounds like a faulty logic board then...
@oldturkey03 - Any thoughts?
door
@beanman56 - Often I find the GPU power rail is shorted to ground. Inferring a short with in the GPU board likely a burnt cap.
door
56 commentaren meer tonen
Voeg je antwoord toe
tomytom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 489
