Ga door naar hoofdinhoud
Krachtige tablet van de 2e generatie, uitgebracht door Apple in juni 2017. Model A1670.
What caused my ipad pro to shut off mid use?
So I was using my Ipad pro (procreate app) drawing no previous issues, I hadn't recently updated, it is running IOS 15.5, mid use while I was drawing the ipad shut off I tried to do a reboot using the home button and the power button and nothing. I cant even get the apple logo its completely dead. The battery as it shut off was about 18% and it was plugged into the mains while I was using it. The back of the ipad was warm but not hot. What do you think could have caused the issue? Is it a motherboard issue? It has never been dropped, no liquids spilt on it.
Is dit een goede vraag?
4 opmerkingen
It processor is weak
door
@mahendra here is your chance to shine and to explain this a lot better. What are you referring to when you say "It processor is weak"? What do you mean by that? It might be easier to explain this in whichever language you prefer. Sometimes a lot gets lost in translation.
I moved this from an answer to a comment to minimize the damage ;-)
door
So I took the Ipad to a repair shop and they told be the motherboard must have had a power surge that essentially fried its brain.
door
@Becka it's possible. But based on what you said I am likely to think it's probably repairable by the right repair shop. The board itself can be fixed, but not every shop performs those sorts of repairs.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
It could definitely be a motherboard issue, but could also be any number of other things, including a faulty battery.
Couple of things I would try. Have you tried other chargers? or plugging it into a computer? You said the back was warm, but not hot. Warmer than usual?
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Becka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 26
Altijd: 618
