Ga door naar hoofdinhoud
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Fix worn out ABXY buttons (switches/contacts?)
My ABXY buttons, particularly A are not responding well. Needs too much pressure to register an input.
How would you fix that? Are there just contacts and a spring that need to be cleaned? Or are there switches that you can buy separately and replace (if so I couldn't find any)? Or would you need an entirely new board?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@theunit19 could be the plastic switches that you push down on a membrane. Take a look at this video and at 8:00 you see what those look like. You see where the membrane close the switches when depressed. Sort of like the buttons on a remote. You can clean those with a pencil eraser and some isopropyl alcohol. Replacing the plastic push buttons may also help. these guides will help you to work on your controller Xbox Elite Wireless Controller Series 2 (Model 1797)
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thank you! I will try that once I get the right tools.
door
At first I did clean the switches both on the board and on the rubber part with isopropyl and some cotton swabs (forgot about the pencil eraser). It helped for about 3 weeks.
I just got a replacement for the rubber switch part for just 5€ and it seems to work nicely.
door
@theunit19 excellent. GReat when a good plan comes together. Remember, REPAIR IS WAR ON ENTROPY! :-)
door
ALSO! Be sure to update your controller's FW via the "Xbox Accessories" app on PC available through the Microsoft Store.
I think xbox does this automatically? Maybe if you plug it in?
door
Voeg je antwoord toe
Enji zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 119
Altijd: 3,033
