Ga door naar hoofdinhoud
Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
165 Vragen Bekijk alle
Is it easier to replace the back glass, or the entire back housing?
The back glass on my iPhone 12 is broken, and it needs to be repaired so I can trade it in. I don’t have a laser machine. Would it be easier to replace the back glass, or the entire back housing? I think that replacing the back housing might be easier, because I won’t have to destroy the back of my phone more.
Thanks in advance :)
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
getting the glass changed by someone with a laser maybe a cheaper option than buying a housing, you would probably need an original housing for a trade in and they would probably be the more expensive option
Was dit antwoord nuttig?
Score 4
5 opmerkingen:
Okay cool. Sorry for the noob question but what specs would the laser need?
door
@isaacnaylor do you mean what power is the laser diode ?
door
like i don’t know anything about lasers
i know someone w/ a laser engraver, but i think that an engraver and marker are different. like isn’t there a certain wattage or something?
door
@isaacnaylor most lasers for back glass are between 6-8w, i dont use 1 personally i use a hot air station to do back glass replacement. i will add a photo to an answer to show you an iphone x i did
door
ok thanks so much
door
Voeg je antwoord toe
Isaac Naylor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 386
