Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in september 2016. GeĂŻdentificeerd door modelnr. SM-G610
Testing with another device's screen
I got a J7 prime with a completely dead, broken and miserable screen.
Took it apart (not wearing gloves, oops) and seems like the rest of the components is fine.
So I got a spare screen from a J5 prime (which has the same connector), then tried to turn it on from USB power... No success.
Is it correct to deduce that the phone is dead? Or is it simply not compatible with another model's screen?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi @sharkaroid
Here's the No Power troubleshooting flowchart from the service manual that may help.
Looking at the chart, if there is no power on sound or vibration sound then there's a problem with the systemboard.
Afbeelding
Was dit antwoord nuttig?
Score 2
1 Opmerking:
@sharkaroid it is possible that your incorrect display is actually preventing your phone to come on. Remove the wrong LCD altogether and give it a try or even leave your old one connected. Like it was previously stated, if you do not get any vibration etc. on startup, the issue is not your display.
door Deel
You’ll need a matching screen. Not all screens are compatible even if the connectors fit.
Score 1
2 opmerkingen:
but even with an incompatible screen, would the phone turn on and vibrate if it's working?
door Deel
@sharkaroid Even without a screen the phone would still turn on.
door Deel
Voeg je antwoord toe
Ana Clara Forcelli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 599
