Ga door naar hoofdinhoud
HD-actiecamera met touchscreen-LCD, uitgebracht op 5 oktober 2014.
Battery fully charged but camera dead
Dead gopro 4 silver even with fully charged battery
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
If your GoPro isn’t turning on I would try a good SDcard (that’s compatible)and if you have tried that ,open it up and have a look for anything strange in the main board
Keep a eye out for corrosion as it’s quite common on GoPros as people sometimes forget to put the waterproof housings on them
Here’s a guide on dismantling it
GoPro Hero4 Silver-moederbord vervangen
If you see any corrosion try cleaning it away with some isopropyl alcohol
If it’s all clean on the main board I would start looking at the flex cables and if they are all good try plugging it into the GoPro Quik app as it might just need a update
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
John Leslie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 401
