Laptop power on issues
SD card usb lan cable
Issue
Update (09/16/2022)
This white cable is damage i want this
Is dit een goede vraag?
Issue
You will need your exact model number as explained in the HP parts surfer link:
https://partsurfer.hp.com/partsurfer/
You could also download the Maintenance and Service Guide for your model.
Just type in your exact model number and "Maintenance and Service Guide".
This is one possble site:
https://mans.io/files/viewer/419782/1#na...
They may only sell the the cable with the whole part as in your photo.
Was dit antwoord nuttig?
Perform a hard reset.
Inspect the AC adapter, cables, and adapter (DC) port on the laptop for damages.
Verify that the wall outlet is working correctly.
Check the LED indicator on the AC adapter.
Connect a known-good AC adapter.
Disconnect the laptop from the docking station (if applicable)
Run a diagnostic test on the system board
Regards,
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 365
1 Opmerking
A little more detail please if you can?
door mike
