Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
4-inch iPhone uitgebracht in maart 2016 met hardware-specificaties vergelijkbaar met de 6S. Verkrijgbaar in Silver, Space Grey, Gold of Rose Gold met opslagopties van 16/32/64/128 GB. Model: A1662 en A1723
Increasing storage capacity SE
Will increasing the storage capacity of 16GB iPhone SE 1st Gen to 32GB affect the performance or battery life in any negative way? Can it lead to unexpected shutdowns? I was planning to increase the storage to 32GB since 16Gb is too less for me.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hello, Kunal.
While upgrading storage does not typically cause issues, in an iPhone it can definitely have unwanted consequences. Upgrading iPhone storage is a complex and lengthy procedure so it is not recommended especially for beginners.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
What are some of those unwanted consequences? I was planning to get it done from an unauthorised service centre as Apple does not allow it.
door Deel
If you want to do it why not go 128 gb?
door Deel
@Kunal Jain Possibly breaking the device. Since this is an SE first generation I just recommend upgrading especially since it isn't supported anymore.
door Deel
From the research I have done on this, on the SE it is not possible to change the storage capacity from what it originally was when it was manufactured.
door Deel
@garymelechinsky It's definitely possible but requires advanced microsoldering and BGA reballing experience. Definitely not a drop in replacement. Strange Parts on YouTube did a similar procedure on an iPhone 6(?)
door Deel
Voeg je antwoord toe
Kunal Jain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 872
