Ga door naar hoofdinhoud
Released in August 2019.
6 Vragen Bekijk alle
What glue can I use for the battery?
Hi,
I followed this tutorial: https://ifixit.com/Tutoriel/Sony+WF-1000...
I broke the glue when I tried to move it on the new battery. I tried to finalize the battery replacment without glue, but the headphone is not working. I think the contact between the battery and the metalic part is not good without glue.
Any idea what kind of glue I can use and where I can buy it?
Thanks in advance
Best regards,
Maxime
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@maximeang any thin double sided tape should work to hold the battery down. I do not see that this is vital for the battery to make contact. Double check your work and make sure that you battery makes contact even without the double sided tape, check your ribbon cable etc.
As for the tape, anything like this Tesa 61395 Tape would work
Tesa 61395 Tape Afbeelding
Product
Tesa 61395 Tape
$5.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Maxime zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 305
