Ga door naar hoofdinhoud
The fourth-generation Surface Pro tablet, released October 26th, 2015.
208 Vragen Bekijk alle
Removing the Display for a Surface Pro 4 with Glass Screen Protector?
I have a Surface Pro 4 tablet with a glass UAG screen protector that I want to replace the battery. I've removed the display on another Surface Pro 4 using a heating pad so I'm familiar with the process.
For the Surface with a screen protector, I planned on use several iOpeners to heat the edges to soften the adhesive.
Has anyone successfully performed the display removal on a Surface with a glass screen protector?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Just do it the same way as the last one. Which ever way you do it there’s always a chance the protector will come off anyway.
Was dit antwoord nuttig?
2 opmerkingen:
My concern was not so much whether the protector would come off, but whether the thermal expansion between the LCD and the protector could crack the display?
door
Why not just remove the protector then work on the screen replacement?
door
Voeg je antwoord toe
David S. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 119
