Ga door naar hoofdinhoud
Repair guides and troubleshooting for dishwashers made by Electrolux.
10 Vragen Bekijk alle
Help! Used Pipe Drainer into Dishwasher.
Hello, I need some help please. My dishwasher was blocked so I had the 'brilliant' idea to put pipe drainer into it. Obviously it didn't help, we had to call an engineer which came after 15 days to fix it. The chemical stayed in the dishwasher for 15 days, after the engineer fixed it, I run 4x 70 degree cycles but I'm still worried it all the chemical had gone away. Please don't judge me, I was so silly to do that. What shall I do now, will the dishwasher be still contaminated? How can I make sure is cleaned and will it be ever safe to use again? Thanks a lot for any advise.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Just run it through another cycle or two, with soap. Whatever soap you normally use. The soap will help clear any residue from the machine. And repeated cycles will flush that residue from the machine. Should be fine.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you for your reply!
door
Voeg je antwoord toe
Laura De Min zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 69
