Ga door naar hoofdinhoud
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Is there a maximum storage capacity?
My Mac Mini Late 2012 has a Fusion Drive (1 TB HDD and 128GB SSD) and it will not reinstall MacOS because the HDD SMART status is failing. Since the hard drive has to be replaced, I'm looking to upgrade it to an SSD and I'm wodering if there's a size capacity. Can I replace the HDD with a 2 TB SSD? If not, could I replace it with a 1 TB SSD?
Thank you in advance!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
A 2TB SSD should work fine. The 2012 models do not have a reachable storage limit due to being UEFI.
Was dit antwoord nuttig?
Score 1
You will want to remove the blade SSD within the Fusion Drive set.
I just upgraded my 2012 with a new 4TB SSD to hold my media and will likely add in a second.
Think about getting a new blade SSD 512 GB or 1 TB for your OS and apps. It will make your system sing!
Score 1
Voeg je antwoord toe
Tyler VZ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 863
