Ga door naar hoofdinhoud
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
Ipad is not working, PLEASE HELP!
HI,
My son broke his iPad screen, and after a couple of days the iPad started to act weird. NOW, the iPad doesn't work, is stuck on ON/OFF apple logo. I have try to do a DFU and a Recovery Mode too but is not working. I CANT connect to the computer. Any help is appreciated ... I post a mini video showing the problem. Thanks...
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Could be because there is no digitiser connected. On turn on the system checks all components are working. It’s detected a fault (no digitiser signal) and probably refusing to start.
Fit a new digitiser then try it. Did you remove the screen yourself? Before reconnecting the new digitiser etc disconnect the battery or you risk blowing a backlight filter.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
yes, I remove the screen my self!!! It was a messy broken glass… I’ll see what I can do.
Thanks for your answer
door
Voeg je antwoord toe
maylin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 232
