Ga door naar hoofdinhoud
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Why is my SSD showing when start up?
HI,
I Install a new SSD on my late 2009 iMac and when I start my Mac is shows as external hard drive,,, I have select the hard drive and restart the computer several times but keep showing the same. "SSD EXTERNAL HD" . Any help
Is dit een goede vraag?
8 opmerkingen
What is the make and model of the SSD you are trying to install?
door
Samsung Electronics 870 EVO 500GB 2.5 Inch SATA III Internal SSD (MZ-77E500B/AM)
door
OK, that's the right drive for your system.
FYI Your system offers a SATA II (3.0Gb/s) port, many people put in the wrong drive which is too fast. The Samsung drive is one of the few which is able to automatically match the systems port I/O which is why it is the correct drive!
So I guess the next issue is is the drives name the issue of the fact the new drive its self is not booting up? And what is the OS version you are trying to install?
door
Ok,,, let me tell you ( i’m new at all this) lol
I already installed Monterrey on the SSD,
The SSD is already installed inside the imac (I remove the old hard drive and installed the ssd)
everything is operating (SLOW) but is working, I can go to Internet and do search , I can download applications etccc.. The only problem is that when I start up the computer it shows the ssd as external hard drive 😳. Let me see if I can post a short video.
door
Did you swap out the HDD for the SSD or add the SSD to your system?
DO you see two drives on your desktop? Thats a good clue.
door
3 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
OK it looks like the issue you noted is the drives name which you can alter by just clicking on the name field like you change a file or folder. So I suspect you used another system to setup the drive which is why you see external in the name.
But we have a second bigger issue here! And that's the OS you used macOS 12.4 Monterey! Your system really can't use it which is why its deathly slow! The highest version Apple supports on your system is macOS 10.13.6 High Sierra
Here's the specs for your system 21.5" iMac Core 2 Duo (Late 2009)
As you can see at the bottom of the writeup: Pre-Installed MacOS: - Maximum MacOS: 10.13.x
Using your other Mac you'll need to setup a bootable OS installer drive with the proper version of OS. Go here How to get old versions of macOS to snag the correct version. Then using your other system get a USB Thumb drive (32GB) using Disk Utility reformat it to GUID and a journaled file system (HFS+ file system) then follow this guide How to create a bootable installer for macOS
Now plug in the Thumb drive into your 2009 system and reboot, you'll need to use the Start up command Option (⌥) so you can select the USB Thumb drive as the booting drive
Reference: Mac startup key combinations
You'll need to reformat your internal drive as its running the wrong file system (APFS) for this which needs macOS version (HFS+) using the USB Thumb drives Disk Utility. Then using the installer install High Sierra.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Ok, I’ll try that. But Monterrey is supposed to work too I upgraded the RAMs too.
door
thank you for your help
door
@maylin lazo - Who told you that?? Monterey is 64bit OS so it will need to thunk to work on your system which is externally 32bit.
Think of it this way... You have large painting that is twice the width of the door way (in either direction). So clearly it can't fit as one piece! So you need to cut it into half moving each half through the doorway then piece it back together. Thats a lot of work!
Now you have a second house which has a doorway that is the same size as the painting is wide. You can just slide through hanging it in the living room!
Thats the difference between a Core2Duo and the newer Core i5/i7/i9 chips they are full 64bit unlike the Core2Duo which is a 32bit externally but 64bit internally.
So every process takes twice as long to get through the chips interface.
door
door
@maylin lazo - What is confusing you?
door
Voeg je antwoord toe
maylin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 146
