Ga door naar hoofdinhoud
Google's derde generatie Pixel-smartphone, en hun eerste telefoon met een "inkeping". Wordt geleverd met een 6,3" QHD+ OLED-scherm en 64 of 128 GB opslagruimte. Verkrijgbaar in Nearly White, Just Black of Not Pink.
Part for insulation tape?
Changing my battery due to the phone overheating and I noticed the insulation tape was torn. I cannot seem to find a replacement part for this anywhere. Can anybody point me in the direction of the part or a workaround to fix it?
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Hi
I wouldn't worry too much about this tape as it docent appear to be connecting to anything,heres what I would do!
try your best to straighten it out and get some non-conductive tape such as sellotape or electricians tape to put on top any that should fix your issue the best I can be fixed as I don't know of anywhere that would sell you a custom cut piece of this type of tape.
if you have anymore questions please ask
hopefully this helps
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
This is what I was thinking of doing but had one thing holding me back. That insulation tape seems to be connecting to a heat sink from the battery to keep the board cool. Will electrical tape be able to transfer the heat from the battery to that heat sink?
door
@Justin O
I don’t think it would matter too much as tape is horrible for transferring heat(that sort of thing wouldn’t make a difference in a cooling system)when its that thin,I think the tape is more just part of the manufacturing process rather than a essential part of the phone so the electrical tap will do just fine:-)
door
Thanks, going with the electrical tape for this!
door
@Justin O
That great:-)
door
I tried using some metal foil tape, thinking it would conduct heat better, but now my GPS isn't working. I think the foil is shielding, reflecting, or otherwise interfering with GPS satellite signals. So don't use metal tape!
door
2 commentaren meer tonen
To anyone else watching this thread, this isn't regular tape. This is a graphite thermal pad.
Voeg je antwoord toe
Justin O zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 33
Altijd: 827
