Ga door naar hoofdinhoud
Apple's nieuwe pronkstuk, die op 24 september 2021 werd gelanceerd, bevat een 6.1" ProMotion OLED-scherm, een nieuwe, driedubbele camera-opstelling en 5G. Opvolger van de iPhone 12 Pro.
20 Vragen Bekijk alle
Broken LiDAR Scanner iPhone 13, rear system change
Hi, I replaced a damage iPhone with a pulled rear system form another iPhone, but have not transferred the former LiDAR Scanner. As there is a manual for this on here, I used the LiDAR sensor from another iPhone, but it seems to be paired to the iPhone as well. Has anyone ever exchanged a LiDAR Scanner successfully, so one that was not installed in the original device? The measure app (to test the LiDAR) just freezes….
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The lidar in the pulled chassis probably isn’t compatible with the motherboard. Normally everything must be swapped over between chassis’s.
Was dit antwoord nuttig?
Score 1
It might be possible you did everything correct. The housing might have the wrong LiDaR filter installed. A lot of housing suppliers will use something that looks right from the outside but doesn't function like the original filter. My guess is that it's not even a filter at all, just some paint. If you still (it's been 3 years) have the original housing, you might be able to transfer what's left of the original filter to the new housing (after you scratched off the knock-off paint inside the back glass)
https://www.reddit.com/r/mobilerepair/co...
Voeg je antwoord toe
MacMarcus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 27
Altijd: 743
