Ga door naar hoofdinhoud
De Logitech UE Boom 2 is een waterbestendige, draagbare Bluetooth-luidspreker die bekend staat om zijn 360-graden geluid. De Boom 2 is verkrijgbaar in een veelheid aan levendige kleuren en patronen.
Why my speaker is not powered?
Hello guys,
First of all I'm not an english native speaker so sorry for the mistakes.
Couples year ago my UE BOOM 2 fell into sea water and it didn't work anymore, when I get home I just put it in rice and and it stayed in for a very long time. 2 days ago I tried to charge it (there is the blinking white light) and to turn it on and it worked for like 30 seconds I was able to put music and then it turned off saying that there was no more battery. Basically every time I plug it and I wait a bit I can turn it on during few seconds. I managed to unplug the battery (Li-ion 3.6V 3200mAh) and tested it with a voltmeter. It says that the battery voltage is 4V, then I concluded that the battery was fine and there was an issue with the powering of the speaker. My questions are : have you ever seen something like this ? Do you have any advices about the pieces I should test or replace ? Does anyone know how to fix it ?
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You should look at the PCB inside of the speaker as well as any connected terminals. Since it fell into Sea water I suspect that there is major corrosion going on despite the rice.
Was dit antwoord nuttig?
Voeg je antwoord toe
Eliott Guira zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 279
