Ga door naar hoofdinhoud
Tips om optimaal van iFixit te genieten.
22 Vragen Bekijk alle
I plugged a 110 v iron, it did not heat
I installed a 110v outlet using one live wire and a grounded wire. I measured the outlet to be 125v. When I plugged a 110 v iron, it did not heat. The iron is working in other 110v outlet., but not in this extension outlet. What is the problem.
Is dit een goede vraag?
1 Opmerking
Hi
From what I know ,different houses are wired in different ways to I would check nothing has tripped your safety box:-)
Just in case
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@rogergusilatar Look at how the functional outlet is wired. Copy that or use an electrician. Your house wiring depending on it's age might have only two wires but in anything modern that ground is there to be exactly that: a ground, sounds like you may have miswired the outlet. this page explains how to wire the outlet properly. Black to brass, white to chrome/silver, green to ground.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
@uchetil they may be using the actual terminology. A grounded conductor is one way electricians refer to a neutral wire. A groundING conductor is what most people refer to as the ground wire.
door
Voeg je antwoord toe
Roger Gusilatar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 45
