Ga door naar hoofdinhoud
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
22 Vragen Bekijk alle
My humidifier heater isn't working.
My Airsense 10 is about 2 years old. My humidifier heater quit. I pulled the cover and checked the fuse and it is good. I don't have a schematic to check the test points. Could you give me some info on the heater?
Thanks!
Is dit een goede vraag?
1 Opmerking
Yes this is the fuse under the heater plate. I unclipped it to test its continuity.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Bg Higg by checked the fuse I assume your are referring to the one under the heater unit like shown on here Data on the heater is not freely available so I would go ahead and replace the heater on use a bench power supply to see if that could run the heater.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Bg Higg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 125
