Ga door naar hoofdinhoud
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
J9001 something inside blocks my cable connector
Imac genius, refer to my two photos, do i need buy a top magnifier to check what inside J9001 is blocking my cable connector?
I see 12 metals from above. Which pin(s) block me? What is doable to enable cable connector insertion 100% into board connector?
(Out of careless mistake, my screen fell down desktop last week. The connector is partially broken)
Update (06/13/2022)
This is my existing insertion situation.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You need a new connector at its physically damaged. There is no means to make this work as the socket pins are a fork type. While you might be able to insert the cable end it won't make electrical contact with the mating connections.
As much as I would love to offer you a magical answer to make this work I just can't (nor anyone else can either).
Was dit antwoord nuttig?
1 Opmerking:
Thx Dan. Soldering on such very narrow space is like launch a rocket to the moon to me... Cannot shake hands, must have eagle eyesight... I will try buying some used tools to fix it asap. Thx your insights and selfless sharing. U give me a hope.
door
Hi Dan,
I fixed it.
After purchasing the original logic board connector from taobao, I realise that a quick fix is to remove the front cover, and erect the 6 pins upright 90 degree to the floor.
The board connector & cable connector at J9001 eventually fits to each other firmly.
My solder skill too poor. I am too poor to buy a professional hot wind gun. The above solution is quite happy to me.
Thanks Dan. I posted my previous wrong thoughts and my final outcome. Just use a mini 1-shape screwdriver to erect the pins...fixed it...the pins were tilted to screen side (as opposed to electric power back side ) due to screen drop onto desktop.
Voeg je antwoord toe
pmp calvin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 205
