Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
Components missing in an area of ​​the board
Hello. I need help!
I made a post about a component that would be missing from my board after it undergoes oxidation.
A collaborator helped me by indicating the missing component, but when looking at the photo sent by him I realized that more components may be missing.
Again I ask for the help of the community!
Thanks in advance for your help and I'm at your disposal.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The best way to figure things out is by snagging the boardview drawings and schematics. They can be found on the Internet! Do a Google search for the board number 802-2530 sometimes it takes a bit of searching Like this
To help to locate if the files are out in the wild I reference this board Logic.WiKi
Between the two you should be able to ID any component on the board!
Was dit antwoord nuttig?
Score 2
The board is scorched by an overcurrent fire. The reason doesn't matter anymore - maybe a loose part having shorted the circuit. It should have been smellable.
You must replace the board. Look for a replacement board (eBay, iFixit etc.) and the procedure description in iFixit or elsewhere. I do this scores of times with a different MacBook, thus prolonging its life for eternities.
Good Luck!
Voeg je antwoord toe
wagner.m.v zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 124
