Ga door naar hoofdinhoud
Checking to see if Optical drive swap is possible
I'm looking to swap the SuperDrive from my PowerBook G4 Aluminum 12" 1.5 GHz for drive in my Model A1176 Mac Mini and vice versa. I'm just checking that these compatible? As far as I can see it looks like it.
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
PowerBook's take a 12.7mm PATA Slot Load Optical drive.
The Mac Mini A1176 also uses at PATA 12.7mm drive..
no problem with a swap.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thanx for the clarification Matt., I was comparing hard drives instead of the optical drive.
door
Kind of weird that the Mini has a Sata drive but a Pata superdrive.
door
Sata Optical drives were slower to catch on. Apple Added them across the board Late 2008 - Early 2009
door
Voeg je antwoord toe
David Pagan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,013
