Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Apple Watch Series 2 werd aangekondigd op 7 september 2016 en uitgebracht op 16 september 2016.
Red Apple logo after Battery replace
Hello, I've replaced a battery in my AW, it was working fine. Day after the battery was replaced, they stopped working. When I turn them on, the Apple logo is red a fades away. The screen is black, but they are on - I can see them with my phone, the notifications are working and I can use "play a sound" in Find my device app. Can you help me with solving this problem please?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi
I know how you feel because the same thing happens to me when I was doing a stainless steel series 1,the issue I had was the battery connector was torn a little bit and the display cable had a small amount or abrasion on it so it was one of the two
My advice here would be to get some isopropyl alcohol and clean the battery connector and the screen connector just in case there is some dirt that isn’t visible to the human eye
And I would also inspect all the cables for damage
If this doesn’t work give me a shout and il try and further assist you!
Hope all goes well
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
So I tried all of these and still nothing, I've also tried the old battery and the red logo is still there. I can send a video if it could help.
door Deel
@Vlastimil Hrabovský
If you could do that it would help
Thanks^_^
door Deel
Voeg je antwoord toe
Vlastimil Hrabovský zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 560
