Ga door naar hoofdinhoud
Reparatiehandleidingen voor een breed scala van keukengerei.
Clean the limescale on the kettle
We have a disc electric kettle at work, we use it for more than a year, there was a scale on the disc, it became unpleasant to drink tea. Just rinse and rinse does not help, what can you clean? I would be glad to hear your suggestions!
Is dit een goede vraag?
Score 1
1 Opmerking
Fill pot to minimum level, add a teaspoon of cream of tartar. Stir contents or swirl the pot a couple of time to mix the powder with the water. Boil water until it shuts off. Pour out contents. Rinse pot several times.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Buy some citric acid power and put a table spoon to the kettle with water. Boil the kettle and most of the calcium should break off and dissolve. After the kettle has cooled rinse with water and wipe clean. If it has not removed all the limescale just repeat. Citric acid is food safe and natural.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Run vinegar through it (boil it) a time or three this will remove the mineral deposits repeat until you see its all good. The vinegar is acidic and especially heated eats the basic lime away.
Score 5
6 opmerkingen:
Agreed. Vinegar makes an excellent calcium/lime deposit remover. OP make sure you let the vinegar sit on the scale build-up so that it has time to work!
door
Brandon is right you can heat it before end of day then leave it soak overnight (off, for safety)
door
You could even use some lemon juice or something as well
door
Anything mildly acidic,. Yes. Coke for example LOL.
door
This also works on shower heads and so on. As Brandon pionted out soaking helps so does agitation. Heat speeds up chemical reactions. A bit of scrubbing once softened helps too.
door
1 commentaar meer tonen
baking soda and boil it 2 times and then do it the 3rd time with plain hot water then tip it out and put fresh water in it and its ready to use again.do that every 3rd week
Score 1
1 Opmerking:
Baking soda is wonderful stuff for removing/controlling odors, will cut grease quite well and lots of other things but its a base, not an acid so this will work to control odors, yes.
door
Voeg je antwoord toe
Lia Hughes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 123
Altijd: 1,730
