Ga door naar hoofdinhoud
Optical Drive doesnt work
I keep getting an error message when trying to burn a disc from iTunes. Something to the effect that the disc is not recognized. Then the cd gets spit out of the machine. Took it into a mac store and they said we needed a new optical drive. I'm looking for a suggestion for which drive to use. Thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You can get this one.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
The optical drive may only need a laser lens cleaning. Before buying a new one you could take it out of the machine, open it, dust it off with compressed air and clean the laser lens with isopropyl alcohol.
Score 3
2 opmerkingen:
Aren't there like cleaner disks too you can stick in there?
door
Sure but manual job is always better.
door
Gentlemen..thank you both for your responses. I've sent a disc cleaner thru it several times..still does not work proper. I'll look into the drive you suggested. Thanks again.
Voeg je antwoord toe
Glenn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,002
