Ga door naar hoofdinhoud
The Dell XPS 15 9560 is a light weight, high-performance laptop released in 2017 that features a thin-bezel 15.6-inch screen with 4k resolution and a 7th Generation Intel Core i3-7100H.
How to permanently disable the 1050
I have this xps 9560 with a fried GTX 1050 and i want to use the pc and just disable the 1050 because right when windows detects the card it BSODs. Any help on permanently disabling it is helpful.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @thattechman,
Don't know as the manual is not explicit but try getting into BIOS > Device Information > Video Controller and check if there is an option there to disable the Nvidia GTX GPU and use the integrated Intel GPU as the primary (and only) display adapter.
Was dit antwoord nuttig?
Score 1
14 opmerkingen:
Hello! thank you for replying. There is no option for device information in the BIOS. These are the options
General
System Config
Video
Security
Secure Boot
Intel Software Guard Extensions
Performance
Power Management
POST Behavior
Manageability
Virtualization Support
Wireless
Maintenance
System Logs
SupportAssist System Resolution
door
@thattechman
Did you look in System Configuration or Video to see what options are there regarding the graphics adapters?
door
It will not go into windows for more than a few minutes before BSODing, when i did get to the graphic adapters it was fine until the gtx 1050 showed up and then almost instantly it bluescreened
door
@thattechman
Try getting into BIOS on startup if possible i.e. don't go into Windows.
That's what I meant about looking at system configuation or video. If there are any settings in BIOS not in Windows
door
All those settings i sent above are from the BIOS, not in windows.
In video all you can do is ctrl the brightness, and in system config it has as follows: SATA Operation, Drives, SMART Reporting, USB Config, Dell Type-C Dock Config, Thunderbolt Adapter Config, USB PowerShare, Audio, Keyboard Illumination, and Misc Devices
door
9 commentaren meer tonen
Voeg je antwoord toe
John Dragonette zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 46
Altijd: 3,115
