Ga door naar hoofdinhoud
Er zijn zoveel zaken die we zouden kunnen als we gewoon wisten hoe het moest. Deze categorie probeert de gespecialiseerde vaardigheden op te lijsten die nodig zijn om bepaalde reparaties uit te voeren.
489 Vragen Bekijk alle
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
Is dit een goede vraag?
Score 1
2 opmerkingen
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
door
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Thanks for the advice oldturkey03 :D
Here's that: iFixit 26 Bit Driver Kit Techniek voor het verwijderen van bits
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
door
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
Voeg je antwoord toe
aaronmiller zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 31
Altijd: 1,172
