Ga door naar hoofdinhoud
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
Cycle light blinking and machince will not start
Cycle light blinking and machince will not start. When you press/hold the start/pause button the machine will beep but will not start. Worked fine last night, now today will not work.
Is dit een goede vraag?
4 opmerkingen
Hi @jaygrieser ,
Please confirm the model number of your washer?
Have you tried disconnecting the power from the washer for ~5 minutes and then reconnecting and see if it works OK, you didn't say?
door
Maytag model MVWB765FW. We disconnected the power but not for 5mins. We will give that a try. Thanks.
door
The washer selection wrinkle free starts blinking and the machine will not start. Cant get this selection off, it is like it is frozen.
door
What ended up being the issue? We have the same issue with ours
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @jaygrieser ,
Check that the lid lock assembly is OK. The supplier in the link was only to show where the lid lock is located and how much it could cost to replace. If the lid lock is faulty and needs to be replaced, there are other suppliers online that may suit you better. Just search for W10810403 to get results.
Here's the tech sheet for the washer. See how to enter the Service Test Mode on p.3 so that you can test the lid lock (display 000) as shown on p.4. Also see how to manually test the lid lock on p.20 Test #8 lid lock.
Prevents the washer lid from opening during wash or spin cycles by locking it. Afbeelding
Product
Whirlpool Top Load Washer Lid Lock Assembly - W10810403
$74.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jason Grieser zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 3,605
