Ga door naar hoofdinhoud
Charging port doesn't work
Hello! When the device is plugged in via the micro-USB port, the device doesn't charge. Does anyone have any experience replacing the port, or know of any other ways to fix this issue? Thanks in advance.
For info, I have tried several cables, as well as connecting to the mains and to a laptop but in no case can the device be turned on.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @es2k6
Here's a video that shows what to try that may help.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Hi. Thanks for the video. I just tried that, as well as updating the firmware with the bose updater. The device is recognised by the computer but still no way of turning the device on.
door
@es2k6
Here's a video that shows how to disassemble the speaker. This should give you access to the charge port and if you have a DMM (digital multimeter) you can check if the port is OK electrically and you can also visually check for any problems on the motherboard
After that it becomes harder as Bose doesn't release any schematics.
door
Voeg je antwoord toe
E S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 3,266
