MacBook Air not turning on Fan spin for a second and gets off repeatly
Hi Friends,
I am using windows 10 on my MacBook Air 2015. While I was working, System got freezed. I thought to restart the machine but after I press power button, itโs not turning on..
I have tried NVRAM, SMC reset, kept charging for more than 12 hours, removed battery connection and tried to turn on directly while power adapter is connected and also I tried Disconnecting and reconnecting the Display, Battery and SSD but nothing helped..
I observed that when I press power button, fans runs for a second and turns off and again turns on and off and it keeps repeating. Machine is failing to boot up..
This is third time I am facing this issue. Last 2 times I tried PRAM reset and it worked. But this time no response from machine. Please help with solution if you have any.. ๐ข๐ข
Thank you in advance.. ๐๐ผ๐๐ผ
Is dit een goede vraag?
Letโs get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
