Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
The size of the square nut?
whats the size of the square nut that is used to hold the battery cover on? Can it be order/found from a hardware store?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Not sure about the size, but I doubt if you can buy it separately. I know that if you buy a new shell (for example at AliExpress), you will get a new square nut, which you can transfer to your current back cover.
Example: https://godofgamingshop.com/collections/...
You could also contact them if they have a square nut available.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Tyrantin DB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 390
